Hi, I've a question about the Alphacool NexXxoS ST30 Full Copper 420mm radiator v.2 Article no.: 14281
In the data sheet and even in the description the dimension are W 460 x D 124 x H 30 mm; they're correct? because a 140mm fan should non fit in depth dimension (typo error?).
The question is the radiator D should fit into a 5-1/4 drive bay (Corsair Obsidian 750D airflow)?
Thanks
Thanks
