The AIO connector on my motherboard has the option to vary the pump flow rate with temperature. Is there any advantage to lowering the flow rate of the Eiswolf 2 pump when the GPU is idle or below a certain temperature? Would doing that extend or shorten the life of the pump? My pump runs at ~2600rpm all the time; seems inefficient if the GPU isn't getting all that hot? Curious if anyone has done this - didn't see anything in an initial forum search. Thanks for your advice!
