Hi there - a couple quick questions about your products. I'm looking to cool 2xdimm ram sticks, but need the inlet/outlet on the side of the block, not coming straight out the top. I've found 3 of your products that may work, but wanted to get your opinion and see if there were alternatives:
How does the g 1/4 -> 5/3mm hose splitter work here? Does the waterflow go in parallel through the splitter? Or is all the water forced through the smaller tubing after entering the mcx distributor?
Can the PCIe pins and the pcie bracket be completely removed from this? do you have a photo with literally just the block of this piece exposed? this might be my favorite option if those pieces can be removed
this one could also work but it's a bit big, and definitely overkill for cooling 2 ram dimms
Thank you!
11769 Alphacool HDX Pro Water - M.2 NVMe 2280 SSD - MCX Version
SSDs in M.2 format are now standard PC equipment. The high transfer rates and extremely low access times allow faster and more effective working or…
shop.alphacool.com
13079 Alphacool Core M.2 NVMe PCIe 3.0/4.0/5.0 liquid cooler
shop.alphacool.com
13726 Alphacool ES Stream LGA 4677 1U
The Alphacool ES Stream is designed for server and workstation processors on Intel's LGA 4677 socket with large processor cores. Due to the large…
shop.alphacool.com
Thank you!
