unfortunately we do not have any information about the PCB-Layout of the "Frostbite PRO". If you send us a picture of the PCB i can check if the Pro edition is also compatible with one of our cooler.
Hi David, thanks for the reply. I believe this product is the result of "Alphacool ES Geforce RTX 4090 Reference Design with Backplate" and inno3d board. It comes as a final product.
sorry i misunderstood your question. And you are right, the "INNO3D GEFORCE RTX 4090 ICHILL FROSTBITE PRO" comes with our cooler. I am sorry I must have mixed up something.
So you are looking for components to build up a cooling loop right?
Yes, looking for something easy to install and as few components as possible. Wondering if a 280mm prefilled rad will do it, but not sure about the pump. I'm totally beginner in this area. I will have this mostly in an open frame setup. Thanks.
You will need a reservoir with a pump like Apex/VPP 755/655, radiator, 6 fittings, tube and liquid. A prefilled radiator will not really help here. You need a complete DIY setup.
