Hello,
I purchased an Eiswolf a few months back for my GPU and it fits and works but the temps are ridiculously hot for being water cooled. I have an Eisbaer CPU cooler for my CPU and it runs really cool but this AIO is really, really hot. With my fans at 80% speed, it is running at 82 degrees in FFXIV (which isn't that demanding of a game) and 80 degrees in Destiny 2. I made a fan curve using argus monitor and have to keep turning the fans up to really high and loud speeds to keep it under 85 degrees. I don't think it should be this hot with a 360mm AIO. Does anyone have any suggestions? My room is also getting really hot because of how how this is getting... I wanted to get this liquid cooler to run quiet and cool but it hasn't really changed all that much compared to the stock cooler that came on the GPU, if anything it is running hotter just not as loud.
Thank you
Thank you
