robinlawrie
hi. i need to know the height of the "17075" 90 degree compression fittings when installed on a waterblock (meaning minus the g1/4 thread)
i have downloaded both of the cad models.. however one is for the "Eiszapfen" model ( not the right one) and the other is for a "alphacool HF 13/18" with no serial number given.
i would assume this was the right one... HOWEVER it looks different from the photographs. the knurled base where it screws into the waterbllock is much slimmer in the 3d model, and thicker in the photos, similar to the Eiszapfen model.
this is critical, since the Eiszapfen is about 2mm too tall for the space i have.
the "alphacool HF 13/18" cad model is shorter and will fit perfectly well. but is that the same as the model "17075" you sell?
basically, which is right, the cad model or all the photographs?
many thanks, Robin.
many thanks, Robin.
