Cayan
Hello all.
Just bought a powerful D5 pump/reservoir 1500LH to add in my loop. I currently have Eisbaer Pro + Eiswolf 2 on a 5950x + 3090 FTW3
I believe the new pump will make the PC look amazing, improve the flow and make my life easier to refill/maintain the loop.
Questions:
1 - Do I need to unplug the Pumps from the 2 AIOs, or I can keep it running as with all 3 pumps on? Which option will improve the water flow?
2 - Is it possible to remove the PUMP from Eiswolf and plug the tubes directly on the block like a regular Water block? ( This is not something Im planning to do now, but just as a matter of information for the future )
Thanks for always the great support on the forum, is really amazing the fast and precise info we get here all the time !
Questions:
