Hey everyone!
I have previously purchased a Eiswolf 2 to cool my 2080Ti. Recently I want replace the Corsair AIO with Eisbaer so I can have both loop together. Is this even possible? I see Eiswolf 2 and Eisbaer Aurora have similar type of quick connect. However I cannot seem to find any user manual showing connecting them together. I would assume the coolant have some sort of compatibility chart
In addition, I see there are Eisbaer Aurora, Eisbaer Aurora HPE and Eisbaer Pro Aurora and Eisbaer Aurora LT. Which one of these will be working best with the Eiswolf 2 I currently have? My CPU is a 9900K at 5GHz. The Eiswolf 2 uses a 240mm radiator, should I aim for a 280mm Eisbaer or a 240mm one?
And most importantly, I would assume having two loops joining together it would work better than having them separate, right?
Thanks!
Thanks!
