Advice for AMD Ryzen 3990X
Branimir
Do you have a recommendation for an AIO system for AMD Ryzen 3990X?
If you don't have such system to offer, do you plan to develop and sell the AIO system for AMD Ryzen 3990X?
We are working on a AIO solution for sTRX4 CPUs. But iam not sure when it will be done. Maybe in 3 month. But you can built very easy your own AIO for this CPU. You need only a big case.
Main part the Eisbaer Extrem Solo: https://www.alphacool.com/shop/radiatoren/radiatoren-aktiv/23345/alphacool-eisbaer-extreme-liquid-cooler-core-280-black-edition
That comes with a big reservoir, radiator and a VPP755 D5 pump. All you need are tubes and 4 fittings and a sTRX4 cpu cooler. One of these cooler:
