agapitox
Good morning,
I have an AIO Alphacool Eisbaer 360 CPU, in which I am thinking of adding a radiator more than 240, will I notice improvement? is to cool a i9-10850k with a little OC to which I put continuous workloads and with the 360 aio makes me thermal throttling easily.
At first, I had thought of acquiring a 240 radiator (NexXxos ST30 Full Copper 240mm prefilled AIO Edition) but I see that there is no stock until the end of June.
So I have thought of buying the radiator and connectors loose and fill the circuit. can you tell me what components I would need for this?
Finally, what is the order to mount it? I was thinking of putting the 240 radiator at the top of the tower and the 360 in the front.
Thank you very much
Thank you very much
