Hi!
Im trying to find a AIO solution for cooling a 500w COB LED and i thought maybe you guys could help me. Efficiency of the LED is ~0.2, so at least 400w will be just heat. Operating temperature should not exceed 60 °C. Is there any way to cool this with a compact, maintainance-free solution? Maybe the Eisbaer LT360? Or maybe a "custom" AIO solution like a NexXxoS ST30 Full Copper 560mm with an cpu cooling block with an integrated pump (like Eisbaer LT Solo)?
Sry if these are some kind of stupid questions, but i just can't find out how to calculate if a cooling system is capable of cooling a specific device. If someone knows a way to do that i would appreciate some infos or links. Right now the only way i see is trying it out...
Thank you, Darius
Thank you, Darius
