Alphacool Aurora HardTube LED Ring & D-RGB
harz62
Hello,
I recently bought some Alphacool Aurora HardTube LED Ring 16 mm- Digital RGB and are place around my tubes. It seems that D-RGB is not compatible with Eis-matrix product which seems to support only classic RGB technology. I have some difficulty to choose RGB controller I want. Standalone controllers seem offer more flexible choice than ARGB motherboard technologies. So my questions are:
- Do you know some controllers which are compatible with Aurora Hardtube LED ring ?
- Do I take hub controller (generic) compatible with ARGB motherboard technology instead ?
Thank you for response.
Metropolis34
Hi There,
The Aurora LED has a normal 3PIN connection and can be used with any standard Digital RGB Controller.
Sure you can use the hub controller instead of your motherboard ARGB.
Daniel
Administrator
We also have a small aRGB controller in our store:
It has quite a lot of modes:
