• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
Alphacool Eisbaer 240 AIO hose shortening
Magvay
Hi!
I've recently bought Alphacool Eisbaer 240 AIO.
Performance is best and I'm happy with it, but my case (Sugo 15) is small, so the hoses do not fit inside properly.
I'm thinking about shortening the hoses.
The questions:
Is the Alphacool Eisbaer 240 AIO demountable? Can I disconnect the hoses, cut them and reconnect them back?
Do I need any additional consumables for this?
Thank you.
We are using normal G1/4" threads for the fittings. So you can disassamble everything like you want. But you will lose the warrenty. Keep that in your mind.
One point.... it is very important, that the pump never runs dry. So if you fill the Eisbaer again, be carefull. And for refilling, you will need new liquid. Please dont use the old liquid. Something like Tec Protec 2 or Apex Liquid ECO would be fine. And a small funnel is also very helpfull to fill the Eisbaer.
