Alphacool Eisbaer 280 AIO Life Expectancy
gvansly1
Title says it all, so how many years should I get out of this model. I purchased it in December of 2020.
Thanks in advance!
There is no direct lifetime. This depends on many factors such as runtime, ambient temperatures and heat generation during operation. Depending on the use, the AIO can run for 3 years or even 8 years and longer. This cannot be determined exactly. If the cooling performance decreases, it is usually more likely due to a dried out thermal paste. I would replace it every 2 years. Otherwise, the AIO is only defective when the pump fails at some point, more can not be broken.
