Alphacool Eisbaer Aurora 360 Troubleshooting
tmcraig008
My PC keeps switching off, i thought it was the psu, so upgraded that. Wasnt the case, i noticed in bios that the cpu temp was hitt 100 degrees then swtiching off. How do i troubleshoot if the Eisbaer is at fault. All the fans are running, i dont see any bubbles or movement on the pump. how can you tell if its working or not?
Thanks,
Craig
Thomas_S
How many rpm does the pump run at? That would be one way to check if the system is working. Have you mounted the cooler correctly on your CPU? Does the contact pressure between the cooler and the CPU fit? A photo of the CPU after you have removed the cooler would also be helpful.
