Lucci D.
Hello,
I want to purchase the: Alphacool Eisbaer Aurora 420 CPU
(https://www.alphacool.com/shop/sets...aer-aurora-420-cpu-digital-rgb?number=1016665)
And since the tubes are probably to short in my case I thought about directly extending it and integrate my GPU....
I found out that this Alphacool Eisblock GPX-N Plexi Light RTX 2080 (Super) M5 would be the right fit for my GPU.
(https://www.alphacool.com/shop/graf...eisblock-gpx-n-plexi-light-rtx-2080-super-m05)
Now my question(s):
Is that the proper Cooling Eisblock (GPU) for the AIO?
Is the pump able to handle the addition alone?
Can I just Integrate it with these Tubes? Alphacool Eisbaer TPV Extension Set 90°
(https://www.alphacool.com/shop/schl...-900-schlauch-und-anschluesse?number=1019316=)
Or would I need to buy more connectors, if this is the case which parts are recommended?
Now my question(s):
