Alphacool Eisbaer Aurora tubing advice :)
SiD996
Hi
I have recently brought an Eisbaer Aurora and i am eagerly awaiting the Eiswolf Aurora to complete a full loop with these 2 awesome looking products, the issue im going to have is i have a relatively small case (meshify c) . so my question is is it possible to cut the existing tubes and reuse the existing fittings to make the runs smaller ? as i do like the look of the black tubing , are the fittings "glued" to the tubing or are they just normal compression fittings ?
any help would be amazing
cheers
All our AIOs are using normal G1/4" fittings wich are not glued ;-) You can change them how you want.
