Alphacool Eisblock GPX-N Plexi Light Nvidia Geforce RTX 2080/2080Ti M02 (2070 & 2080 Super) - incl. backplate
Hefox
Good evening,
Could you please let me know if Alphacool Eisblock GPX-N Plexi Light Nvidia Geforce RTX 2080/2080Ti M02 (2070 & 2080 Super) - incl. backplate (11682) is compatible with Gigabyte RTX 2700 Super Gaming OC?
Thanks.
Regards,
Marius.
Vanzin
Hi ,
We are sorry but at the moment we do not have any information about the used PCB Layout of this graphic card. If you send us a photo of your graphics card without the original cooler we can check if we have a compatible water block for your graphics card.
Vanzin
Hi Thanks for the Photo. The 2080/2080Ti M02 water blocks are compatible with your graphics card.
Could we use your photo for our GPU configurator so we can add the graphic card to it?
Hefox
The photo is taken from a french website that tested this card so not sure we can use it without their permission.
Thank you.
