Alphacool Eisblock water cooler for RTX 3080/3090 Reference PCB is available now!!!
Compatibility list:
ATTENTION: The following models were visually checked for compatibility. Please note that this list may change at short notice.
More compatible models will follow in this list for this cooler. We are currently checking other PCB designs from various manufacturers!
RTX 3080
Zotac GAMING GeForce RTX 3080 Trinity (ZT-A30800D-10P)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXMPB)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXPPB)
Inno3D GeForce RTX 3080 iChill X4 10240 MB GDDR6X (C30804-106XX-1810VA36)
Inno3D GeForce RTX 3080 Twin X2 OC 10240 MB GDDR6X (N30802-106XX-1810VA34)
Inno3D GeForce RTX 3080 iChill X3 10240 MB GDDR6X (C30803-106XX-1810VA37)
Palit GeForce RTX™ 3080 GamingPro (NED30800191A-132AA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3080S191A-132AA)
Galax GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NN)
KFA2 GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NK)
Gainward RTX 3080 Phoenix
Gainward RTX 3080 Phoenix GS
Galakuro NVIDIA GEFORCE RTX 3080 GG-RTX3080-E10GB/TP
RTX 3090
PNY GeForce RTX 3090 XLR8 Gaming EPIC-X RGB, 24576 MB GDDR6X (VCG309024TFXPPB)
Inno3D GeForce RTX 3090 iChill X3, 24576 MB GDDR6X (C30903-246XX-1880VA37)
Inno3D GeForce RTX 3090 Gaming X3, 24576 MB GDDR6X (N30903-246X-1880VA37N)
Inno3D GeForce RTX 3090 iChill X4, 24576 MB GDDR6X (C30904-246XX-1880VA36)
Zotac GeForce RTX 3090 Trinity, 24576 MB GDDR6X (ZT-A30900D-10P)
Palit GeForce RTX™ 3080 GamingPro (NED3090019SB-132BA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3090S19SB-132BA)
Galax GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/ (39NSM5MD1GNA)
KFA2 GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/
Gainward RTX 3090 Phoenix
Gainward RTX 3090 Phoenix GS
Galakuro NVIDIA GEFORCE RTX 3090 GG-RTX3090-E24GB/TP
Technical data:
L x W x B: 224,9 x 121,4 x 25,5 mm
Material cooler: Nickle plated copper
Material top: Plexi
Thickness cooling fins: 0,6 mm
Threads: 4x G1/4“
Power connector Digital RGB: 3-Pin 5V (0,5A)
Further infos in our Shop: https://www.alphacool.com/detail/index/sArticle/27822/sCategory/20538
You can put the LED strip out of the block.... or you dont need to connect the LED connector somwhere... its on you ;-)
Robinekman
Hi guys, just saw there is a water block coming for the gigabyte rtx 3080 gaming oc(GV-N3080GAMING OC-10GD) Will this block fit the gigabyte rtx 3080 eagle oc (GV-N3080EAGLE OC-10GD) as well? If not, are you going to make one for the eagle card?
Lequu
Hi! Are you sure that Zotac Trinity will fit? The block is 224,9 mm long and and TPU measured the card at 22,5 cm. Their "reference" board is slightly longer than others for some LED/fan connectors.
Zotac Trinity PCB
Yes, our cooler will fit on the Zotac Trinity. They only made the reference PCB a bit longer with some more connectors, but we have a cutout for this, dont worry.
JamesWoo7
Hi, I currently own the Alphacool Eiswolf GPX-Pro AiO for the RTX 2080/2080Ti. Im going to soon be upgrading to the RTX 3080, Would it be possible to replace the current 2080 MO2 block on the AIO with this 3080 block, Would it just be a matter of detaching the quick release hoses and connecting them to this block ? I have spare fluid, And I know how to top up the radiator if needed
Thank you
Metropolis34
This is not possible it would not fit.
The block does not have an integrated pump in it. If you want to run the block with your old Eiswolf radiator you need to buy seperatly a pump and a resorvoir to run the system.
