Hello, I received today my order including the Alphacool Eisstation DDC reservoir incl. Alphacool Laing DDC310 pump.
As you can see in the photo I've attached, I've 2 main mounting possibilities in my case (InWin 303/305).
1. Mount the Eisstation vertically: is this possible? How can I fill the loop, flipping the case horizontally, then when finish put it back to the right position?
The metal bottom fit the blue dots screws.
2. Mount the Eisstation horizontally, in red dots screws. This is what I want to do, seems more secure to me. I need a mounting bracket that fit 120mm fans. Is the Alphacool pump mount universal for 120-140mm fans/radiators ok and fit the metal bottom of the Eisstation?
Thanks
Thanks
