kevindrewes
I bought the first flow sensor and put it in July, and it failed withing 6 weeks (no signal output.) The reseller, Titan Rig, was of no help. I bought the sensor through Amazon, and, even though outside their return period, they replaced the sensor with another identical unit. This one worked very well, for 10 weeks. It then developed a crack at the output fitting, even though I only finger-tightened the fittings, and started to leak. It also shows signs of starting to leak where the signal lead exits the housing.
Can you do anything to help me with this? Four months and two sensors is very poor life.,
