Alphacool NexXxos XT45 1260mm in//out let?
labizoni
Hi all, I've got a setup with a XT45 1260mm and I will be adding a second one then I wondered about the inlet and the outlet of the rad. Does it matter? Is there a optimal port to be used as inlet and outlet?
TIA
HI,
our radiators doesn´t have a specified In or OUT port. YOu have on e one side left and right ports, which can be used as IN and OUT. Depending on the radiator up to 3 on each side. ONe of them can be used as IN or OUT. THe other ones has to be closed. SOmetimes you have also a fill and Drain port on the other side. This port can´t be used as IN or OUT.
Thanks for getting back to me. So then it is fine to use port 2 as inlet, port 1 as outlet, and port 3 as drain?
Back
