Hi, I recently purchased the 1260mm radiator and it has 3x G1/4 ports. Two on one side and one on the other side. What is the layout of this radiator and which ports can I use as inlet and outlet.
The side where the two g1 / 4 inch connections are for the inlet / outlet. The single one can be used to fill or drain the radiator, depending on the installation situation.
Thank you very much! That clears it all. I also found a spec PDF on performance pcs store saying the same thing
"The Alphacool NexXxoS SuperNova Radiator offers two G1/4" threads for IN and OUT. A further G1/4" thread on the back of the radiator serves as a fill port. Alternatively, a temperature sensor or a drain port can also be attached here.""
