Hequaqua
I just got these two products. When I mount the rad in the housing, what is supposed to the fill port(single port) is not even close to the hole(rubber grommet) that is at the top of the fan housing. It doesn't matter if I turn the rad or not. If I do flip the rad to have the fill port line up with the housing, then the in/out ports are blocked by the housing.
I thought the whole purpose of having the the housing was to be able to mount everything(fans/rad/pump/etc) and still be able to use the single port as a fill port.
Am I missing something?
