Alphacool presents a new generation of thermal pads. The Alphacool Apex Soft and Rise Ultra Soft thermal pads can be compared thermal paste due to their outstanding properties and efficiency.
The Apex Soft and Rise Ultra Soft thermal pads fill up the unevenness of components significantly better than standard pads. As they can nestle between components better, heat transfer between the cooler and component is significantly increased. The softer consistency of the thermal pads also prevents taller components such as voltage converters or VRAM from being subjected to increased contact pressure from the cooler. The special material does not dry out as easily as standard thermal pads, allowing them to be used for a much longer period without any significant loss of performance.
The Apex Soft is Alphacool's high-end solution for thermal pads and are offered with a thermal conductivity of 11 W/mk and 14 W/mk. The cost-effective Ultra Soft thermal pads of the Rise series will be available with a thermal conductivity of 7 W/mk.
For more information click here: Alphacool Apex Soft & Rise Ultra Soft Thermal Pads
