EKWB will be making a full cover block for the Asrock 6800XT Taichi, it will also fit the 6900XT Phantom, same PCB layoutApparently I am not the only on looking for one. They made a Merc 319 before the card was available, very interesting.
I actually didn't bother waiting, I used the corsair 6800/6900 water block on my asrock. I removed the metal shroud, and shaved the acrylic for the two longer capacitors. Fits fine on the card, nice and tight, although you have to use one side for the tubing, as the PCB covers the other side....Is there going to be a GPU waterblock for the Asrock 6800XT Taichi.
