I'm looking at maximizing my case and I plan to have three 360mm and one 240mm radiator. Bottom 45x360mm intake, front 30x240mm intake, side 30x360mm intake, top 360mm exhaust. There will be a single 92mm exhaust fan on the back of the case. I measured some stuff and I think I can make it all fit using TPV tubing.
Will this be an acceptable amount of airflow cooling for the motherboard, or should I leave the radiator from the front for just two 120mm fans for better airflow to the chipset, VRMs, SSDs, etc. ?
