Ricardo74
Greetings from Spain.
My name is Ricardo. My only watercooled cpu computer has both Alphacool and Aquacomputer components. NexXxoS UT60 X-Flow 480mm radiator, Eiszapfen fittings and borosilicate glass 16/11 hard tubing from Alphacool, and from Aquacomputer it has D5 NEXT pump with an Aqualis borosilicate glass reservoir with fountain effect, both joined by a delrin adapter, and a cuplex Kryos NEXT VARIO with VISION (nickel/nickel) cpu block.
I built it in may 2019 and I have only used Alphacool's Pure Water and CKC coolants. The first time I used Pure Water to check for leakages. After nine or ten hours of testing, I drained the loop and changed to CKC. Gradually, CKC was turning to a light blue color which turned to a darker tone in about four months. Since then, I've been alternating between Pure Water and CKC every four or five months. With Pure Water no color changes (I know it shouldn't be used as a coolant, but temps are fine if not better than with CKC). I drain the loop from CKC and fill it again with Pure Water and the very light blue color that gets, doesn't increase in time. When I change to CKC again, the color change starts as always (light at the beginning and darker from the third or fourth month). It doesn't affect to performance and one and a half year later temps and flow are the same like they were in may 2019, but I'm courious about it.
Is this behavior normal? Is the same likely to happen if I use Alphacool Tec Protect Ultra liquid?
Thank you so much for your time and best regards,
Ricardo.
Ricardo.
