compatibility question
Hello,
Is the flush screw plug "Alphacool Eiszapfen screw plug V.2 G1/4 - deep black" compatible with any Alphacool radiator? Specifically, I need to know if it is compatible with the "Alphacool NexXxoS ST30 Full Copper X-Flow 240mm". I have a problem with my radiator mount on my PC case that causes the stock protruding screw plugs on the radiator to collide with the mount and create a gap between the radiator and the fans. I could cut the metal in the case's mount or just buy these plugs to fix the issue if compatibility exists. Please let me know. Thanks.
The V.2 screw plugs fits only on our V.2 radiators, not on this X-Flow, sorry.
