Compatibility verification for 5090 ES waterblock
Arietids
Upon reviewing the technical specifications, I observed that the thickness of the 1-slot waterblock (No. 10262) is 21.34 mm, exceeding the 20 mm constraint typically imposed for a single slot. This prompts me to question whether the block will be compatible in scenarios with stringent space limitations, such as configurations where multiple blocks are stacked in adjacent slots or in cases designed with strict 1-slot restrictions.
The total height includes the rear fittings. These stick out slightly upwards, but in return, there’s a cutout on the backplate side to allow the cards to be stacked in adjacent slots. I hope that explanation makes sense.
