rdonr
Hi there, I'm working with a custom soft-tube (TPV) loop, an Eisbaer, & a gpu block. Because I live in a region where the costs of shipping coolant is pretty prohibitive I have to go a different route.
What I have: distilled water (for laboratories, i.e. good quality) & EK Cryofuel concentrate (it's the clear kind because it seems that the colored stuff can gunk up). Since the Cryofuel is intended to be mixed with distilled water, I'm assuming there should not be any problem using this in my loop.
That said, this is the first time I'm doing a custom loom with this type of fluid & just want to err on the side of caution.
So, for my question(s)
Thanks in advance!
- Will the fluid consisting of distilled water / coolant concentrate be acceptable?
- Are there any other things that I need to consider?
Thanks in advance!
