Core 100 Aurora Apex Pump dead when received.
Miliski
Hey! 30206166
I ordered a water cooling system with PUM Alphacool Core 100 Aurora reservoir acetal/acrylic with Apex pump. We built up my PC and water cooling system. Everything worked well, water flow was great and temperatures stayed low. Until after a little bit the pump stopped running and overheated a lot. After that I let the pump cool off and tried again with different cables if it had some kind of power outage, but still nothing. So the pump seems to be dead. RGB lights are working but not the pump itself.
Also with order one of L12 Alphacool Rise Aurora 120 mm fan (120x120x25mm) PHT EOL had its RGB cable cut. Fan works, but led lights are not working.
Back
