KumoriRyuX
For the core loop cleaning solution it says to not run in system for more than 30 mins, does that mean after 30 mins the loop must be drained and if further cleaning is required a new batch of solution must be used? Or does it mean that only run the solution in 30 min intervals until the desired cleaning is reached? Does it matter what temp. the solution is at or just needs to be normal operating temperatures or temperatures under load?
