Jochen Bohl
Hey all. What is you opinion to this build.
The most importend point for me was performance from water cooliung and noise.
I modified Corsair 750D to implement 420 mm Radiator (3x 140mm Noctua NF-A14 PWM) at top and 280 mm Radiator (4x 140mm Noctua NF-A14 PWM) at bottom.
Selve made components are:
GPU riser, tempered glas side panel and modified the reservoire with 4 bores to fit with RGB pump cover unit.
Also modified GPU cooler (removed aluminium cover)
The X570 chipset is also cooled with water.
Thanks in advance for repley.
