Custom loop for SFX build i9-10900k+rtx 2080 FE (Ghost S1 MK3)
sdcz6
Hello Team,
I'm planning to built the said loop, just want to know if 240mm rad and this pump combo will do the work?
(NexXxos ST30 240mm + 40 DC-LT Container + DC-LT 3600 pump).
Using 2x2000rpm(120mm) static pressure fan
Sorry I'm using different brand for gpu/cpu waterblock as i wont mention ;)
Highly appreciate your reply.
Cheers,
Charles
Metropolis34
Hi Charles, a 240 mm radiator would be not eonugh to cool both components. Intel has aannounced that the maximum TDP of the CPU is 255 W plus the GPU. Are you planing to use the radiator internal or external? I would recommend to go atleast with a 360 mm radiator.
sdcz6
Hello Metro34,
Thank you for your time, apparently the choice of my case can only fit either a 2x120mm or a max of 240mm rad, and it will be on the internal.
Cheers,
