b4zzz
Hello,
I have looked on the shop, and of all the DDC Pumps, there seems to be only one that has PWM Control
("Laing DDC-pump 12V DDC-1T Plus PWM")
Is that correct?
And if it is correct...
What range is the PWM?
Is it from 0-100% or 20-70% etc. or what?
Because I have read some pumps PWM only works in smaller ranges, example: below 50% or below 70% etc.
Where can i find out these specifications?
Thank you
Is that correct?
Thank you
