Eisbaer 240 pump noise
colinw67
Hi can anyone advise what to do to stop the pump noise please?
Fresh install, rad at top, ive run without any of my case fans going and it is definatetly the pump rattling.
im a noob to these units. Ive attached a video for you.
Metropolis34
Hi there, this does not sound to me like the pump dude. It is more like the fans are tighten too much and they are some how touching the radiator. Just as an idea to see what will happen can you untighten the screws from the fans a bit?
colinw67
Done that, and run without any fans running still the same
Metropolis34
Okay we need to check this out. Can you unplug the pump for a second? While the system is working? But just for a really short time. I still dont think that the pump makes the noise.
colinw67
Ok did as you suggested and located the issue, a fan wire in the psu came away from its hot glue and was clipping the fan blade ! check out the video attached. Many thanks for your help and advice.
