Any help would be appreciated
Last week my PC went nuclear. The temp which never went above 70 on full load, blew past 90 and almost fried the computer. Figured the sudden spike in temp was from a dead pump. Swapped it out for a new one and all seemed good. Turned went to the bios, watch the temp sit around 48 for about 5 minutes then I had to step away. I returned from being away for about 15 minutes to see the water boiling (literally) in the block. The brand new pump is now burned out. Yay. That failure was related to the outlet quick connect that was blocked. I swapped out the connection, now that flows. Swapped back in the old pump, which turned out to be fine, and still nothing. Tore the pump apart again. Nothing seems to be out of order except the reservoir is now white and there seems to be a divot in the flow plate, but can't confirm that being new or old.
CPU: I9-9900K
MB: Gigabyte Auros Master Z390 Eisbaer
GPU: Nvidia 2080TI with Eiswolf
CPU: I9-9900K
