joeymcjoeysalot
I have one on the way along with a gpu waterblock and extra quick disconnect connectors.
I'm fairly confident I won't have any problems cooling my Ryzen 3600 and 5700 xt (reference) with the single 360 rad. If I want to overclock in the future or upgrade the cpu to a 3900x or higher, would adding another 360 radiator be too much for the pump?
Also I have a Lian Li 011 Dynamic. Would mounting the radiator in the side with the hoses at the bottom of the case be a bad idea? I'm worried about getting my gpu block close enough with how close the quick disconnect is to the radiator. I'd rather side mount and do intake with the single rad than exhaust out the top.
