• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
Eisbaer Aurora360 + TPV Extension set - cutting tube ???
Yes, you can cut the tubes. Its only tricky to get the tubes out of the fittings because there is a metal ring wich is holding the tube. So you need a bit time to get the tube off from the fitting.
Maybe its easier to buy only the tube and some liquid..... because you can also dissasamble the fittings from the Eisbaer to change the tube agains a longer version.
Eisbaer Aurora is using 12,6/6,7mm tubes wich you can get in a set with 3,3m length so you can cut the tubes like you want very easy:
Than you dont need any new fittings, adaptors or whatever. Only a bottle of liquid to refill the Eisbaer Aurora like with Tec Protect: https://www.alphacool.com/shop/kueh...7021/alphacool-tec-protect-ultra-clear-1000ml
You can do it like you want. You can also use that adaptor but you will have to refill the Eisbaer too.
Around 400-500ml i am not really sure in the moment but something around that.
