Sascha
Hi there,
I recently built a new PC with a i9 10900k and RTX 2080ti and want to switch to WC because the system, especially the GPU cooler is friggin noisy in this new build (used to be more quiet in old system). In any case, I'm thinking of purchasing the Eisbaer Extreme and was wondering if it will suffice for use on the CPU and GPU with only the one radiator? Anyone using a similar setup and what temperatures can i expect?
Additional questions:
1. Can the Eisbaer Extreme be used with LGA 1200 socket CPU?
2. Which of Alphacool's GPU coolers are suitable for a MSI RTX2080ti Trio?
3. What additional pieces do I need to order to create the CPU/GPU loop with the Eisbaer Extreme?
4. in this loop setup would it be better to have the GPU first in the loop or the CPU first? The GPU is in my system typically far more often used at full load.
