I am almost ready to install the Eisbaer LT (solo) in my AM5 motherboard, and have one doubt. The manual included in the package (V2.00-11.2021) says that "the AM4 screws are put through the pressure springs, washer and the holder, and fixed with the M4 nut".
However I got the current manual from the Alphacool site (V2. 02-08.2022) and it says: "The AM4 /AM5 screws are put through the pressure springs, washers and the holder". Nothing said about the nuts.
So my question is if I must use or not the nuts included in the package.
Thank you in advance.
