Replacing the pictured MSI 1080 with an EVGA 3070ti Ftw3 with Alphacool Eisblock. It appears that the recommended flow direction for the Eisblock is the opposite direction of my old setup. Is it reasonable to run the flow in the opposite direction without a huge performance drop?
The assignment of the In/Out inlets at the Eisblock should already be observed. The cooler is specially designed for this direction.If you change the flow direction, this can have a negative effect on the cooling performance.
