Hi I have fitted the GPU water block but the temps hover around 60 degrees - having read a bit on this forum now I have noticed I have fitted the inlet and outlet the wrong way around. Would this cause the slightly high temps?
Hi @JulesMK ,
you can expect the block to perform a few degrees better with the correct flow direction.
If the flow is reversed the jet plate above the cooling fins cant work as intended.
Hi @JulesMK ,
