Eisblock ES Compatibility
Lucid
Is there any possibility that more GPUs than all ready listed will be compatible with this block?
Or would there be possibility of a block like this designed for EVGA cards (ideally) or MSI/ASUS etc. ? (especially versions with triple 8 pin power)
I'm very interested in it. Kinda worried that the block might go out of stock or on back order by the time I get a compatible card, so I'm tempted to buy it. But then if I can never get the right card I'm out of luck =/ I'm in the U.S. so I think the only brands I have access to is Zotac and PNY (any thoughts on which is better?)
I'm using Lian Li PC-O11 Air. Currently have my GPU vertically mounted but I'd rather use the default mount so I can use a radiator on the bottom and fit my sound card in too. I think with the inlet/outlet ports on the back of the card, this block will fit in the case horizontally.
RTX 3080 - Eisblock ES
Zotac GAMING GeForce RTX 3080 Trinity (ZT-A30800D-10P)
Zotac Gaming GeForce RTX 3080 Trinity OC (ZT-A30800J-10P)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXMPB)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXPPB)
Inno3D GeForce RTX 3080 iChill X4 10240 MB GDDR6X (C30804-106XX-1810VA36)
Inno3D GeForce RTX 3080 Twin X2 OC 10240 MB GDDR6X (N30802-106XX-1810VA34)
Inno3D GeForce RTX 3080 iChill X3 10240 MB GDDR6X (C30803-106XX-1810VA37)
Palit GeForce RTX™ 3080 GamingPro (NED30800191A-132AA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3080S191A-132AA)
Galax GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NN)
KFA2 GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NK)
Gainward RTX 3080 Phoenix
Gainward RTX 3080 Phoenix GS
Galakuro NVIDIA GEFORCE RTX 3080 GG-RTX3080-E10GB/TP
Other option is EKWB's upcoming special edition for 3080 FE.
ES cooler are only for reference cards because Enterprise Customers dont care about custom designs or Founders Edition. One reason is, that the Reference design is the worldwide most produced version of the RTX 3080 and 3090. So its easier to get them.
Lucid
Do you guys have any pictures of this mounted on an actual card? Would love to see it!
No sorry, we are not allowed to show pictures from our Enterprise Customers.
