Hello,
bought an AC-11938 ordered from performance-pcs.com, packaged really well. Put it on my card, and noticed only after that the LED cable was severed (all 3 wires, was only hanging on by the insulation) and the middle plug was crushed.
I repaired the cable from the sever (with solder/hs tubing), and removed the middle plug to attempt to get it to work, but the strip does not appear to be working quite right. I can get all of the red LEDs to run, but anything other than that I get either random colors, or a single white LED (first one on the strip) when attempting a solid white from Aura Sync.
Any ideas? what do I have for options? the strip doesn't look to be replaceable easily on the block, and I'd rather not be out of a block to replace it. Block works great outside of the RGB.
Thanks,
-Nick
Thanks,
-Nick
