just a quick question.
i was wondering if the first geration of Eisblock Aurora for the Amd RX 5700 xt uses the Eisschicht Ultra Soft or some other themal pads?
And what products use the Eisschicht Ultra Soft ?
All of our 5700XT custom water blocks are using the new thermal pads Eisschicht Ultra Soft. The only one which is using the old thermal pads is the 5700Xt reference water block.
