Elmintrude
Hi,
I've connect my Eiswolf 2 and Eisbaer into a single loop to cool my 3080 ti FE and 3700x. Both have a 360 radiator but I'm seeing higher temps than I expected with them both hitting 70c.
It could well be my fans and other stuff but won't ask advice on that, I'll play around with those. I just want to check that I've connected them both correctly as I am find conflicting information online. First there's this YouTube video on your channel
that shows them set up one way bit then I found an instruction manual that shows them set up another. I've attached screenshots of them both and I currently have mine set up like the YouTube video. My Eiswolf 2 has the new, all black quick releases and my Eisbaer has a single one with the red and blue rings.
Can you link me to the correct way to do it please?
