This is a 3 question post (And also my 1st post ) so help on any or all of the questions is helpful for me
1. I've never installed RGB into a computer before, but want to after installing my Eiswolf 2 Aurora AIO. How do I go about connecting all of the LED wirings from the block and or fans to my motherboard? For reference, I have a Z390 Aorus Pro Wifi Motherboard. Links to videos and or products are helpful too.
2. Upon installation of the block onto my 2080ti, I've noticed that the green "Nvidia..." Does not light up all the time. I'd say 75-80% of the time the Green Nvidia shows up through my case window. Is this normal? If it's not normal and I can fix it, can someone please point me in the direction of how?
3. I have been playing with this card and cooler for about a week, and I'm noticing the temps when the card is under load. what is an acceptable range of temperatures that one should expect when using this card? I know there are a lot of factors that go into GPU temps, but I'm just wondering in general what I should be expecting. For reference, I did follow the Alphacool manual and re-tighten all of the screws after roughly 1 day of (Active) use.
