MBAC1
As the, long, title says I can only fit 1 radiator in my case.. will it be enough for Eiswolf+Eisbear's small reservoir or should I get another small reservoir as well to get more fluid? Also, what fluid should I fill up with in the system/what is already in it?
If I get the MSI B550i, would their non-standard mount work or should I opt for the 30 euro more expensive Gigabyte B550i that also have a third fan header. If so Eiswolf and Eisbear can be on separate headers and the 6 fans can go on the third one.
